PBOY23
318ti wont turn over
Hi there i go start the girls car it goes to fire up but dies everything shuts down i then used our other car to jump start it as i could not really get dash lights or anything it also re - set the time an sterio settings which was strange the car car fired up with jump leads ran mint when i took it for a test drive . Came back turned it off then when to turn it back on an still nothing like i turn the key an as im turning it to full all the dash lights cut out ? an wont fire up under its power so i jumpstartd it again off leads an sweet as but after leaving it sit for over ten mins i still am stuck where i started when i go to start it again ?
Battery is dead as a doorknob. Needs to be replaced.
P.S: Punctuation is your friend.  :rolleyes:
somthing shorted an killed the battery completely the guy reckons its the original old batt 8 years old or so
