Silver Fox 43 Report post Posted November 23, 2009 Looking at doing the conversion away from the box. Seems I need to find a rack which mounts behind the cross member, anyone got any ideas? Other option would be to change the whole front to an E36, only 8mm diff in track. Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted November 23, 2009 Looking at doing the conversion away from the box. Seems I need to find a rack which mounts behind the cross member, anyone got any ideas? Other option would be to change the whole front to an E36, only 8mm diff in track. You might need to look into other marques for a suitable donor that has the rack on the back, similar length (inner tie-rod to tie-rod) & a ratio advantage. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted November 24, 2009 (edited) Hey Dan, Nissan R32 and R33, and sylvia S13 and S14, is the steering rack behind the front cross member? If so, which is the quickest of these racks? Edited November 24, 2009 by Silver Fox Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted November 24, 2009 Hey Dan, Nissan R32 and R33, and sylvia S13 and S14, is the steering rack behind the front cross member? If so, which is the quickest of these racks? no,no,no. use e39 rack as we discussed a while back. from memory the japs use different p/s pressure,hate to blow the seals driving the car on the trailer. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted November 24, 2009 E39 rack is the wrong way around, unless you know of a left hand drive one I can turn upside down. Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted November 24, 2009 E39 rack is the wrong way around, unless you know of a left hand drive one I can turn upside down. e39 sits behind the the cross-member. everyother model sits in front. needs to be the 6 pot engined e39,ofcourse Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted November 24, 2009 (edited) So, do you know anyone who's parting one out? Edited November 24, 2009 by Silver Fox Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 24, 2009 im prity sure e39 sits in front of the cross member. e21 would be more suitable in this case i think! Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted November 24, 2009 E21 is 4.1 turns lock to lock, too slow. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 24, 2009 hmmmm.??! its a hard one Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted November 24, 2009 It seems that the nissan racks do mount behind the subframe, so that's the path I'm going down at the moment. Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted November 24, 2009 (edited) This is from my own car David. From a quick google image search most nearly all Nissan rwd steering racks mount up this way. Edited November 24, 2009 by Jimmy Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted November 24, 2009 yes e39 520i 523i 528i 525i etc . rack looks like this . also nice ali subframe . Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted November 24, 2009 From 300zx.net it seems a 1990 - 1996 Z32 steering rack could be a potential swap This is quoted from 300zx.net.nz "Nissan have given their US-spec cars stiffer damping and quicker steering - 2.5 turns lock-to-lock than those intended for Europe- 2.7 turns lock-to-lock. According to the company's market research, those American drivers who buy sports cars value responsiveness above all else, while European buyers can make more use of high-speed stability." I am not sure where this puts Jap models I would assume the same as the europe models at a 2.7 lock to lock ? Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted November 24, 2009 2.7 would be ideal if the other measurements fitted, quicker than most of the BMW ones. Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted November 24, 2009 Those Nissan racks do looks promising. Its not just needing to be rear mount and the number of turns lock to lock - the tie rods need to attach the same distance from the bottom of the strut to ensure the same steering angle per turn (if that makes sense), then the tie rod ends may need spacing downwards to avoid bump steer. Anything can be sorted with enough effort though. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted November 24, 2009 Hope so Cam, the bump steer problem can also be sorted by lowering the steering rack itself when the new mounts are set up, if needed. Anyone know of a source of nissan zx racks? Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted November 24, 2009 (edited) Sorted myself an E39 rack after confirming it does sit behind the cross member. Should be here by the weekend I hope, will take pics and document for anyone else who wants to do it, if it works. It does need to be the 6 cyl model, the 8's have a box. Edited November 24, 2009 by Silver Fox Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted November 27, 2009 (edited) Ok, have done the mock up and found the bits to make it work, I hope. Have used the E39 rack, and mounted it up to the E28 front member. I'm using E30 inner arms, with E28 outer ball joints, everything seems to match up, thank you BMW for making most of the fittings universal. The E28 is 1180mm from outer ball joint to outer ball joint, as is the unit I've put together. I've had to roll the whole unit a bit to get the steering universal as good as I can, and, yes the E28 u joint at the end of the steering column does fit straight on to the E39 rack, thanks again BMW. Hope to take the motor and box out of the E28 after Hampton downs and then start putting the new stuff together, will let you know how I get on. ps, 3.25 turns lock to lock. Edited November 27, 2009 by Silver Fox Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted November 27, 2009 (edited) How does the length of the tie rods on the rack compare to the length of the tie rods coming off the pitman (I think that's what they're called) arms for the box? (edit) and while I am at it, how's the other geometry look (eg, arms roughly parallel with the lower control arms)? Edited November 27, 2009 by CamB Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted November 27, 2009 Sorted myself an E39 rack after confirming it does sit behind the cross member. Should be here by the weekend I hope, will take pics and document for anyone else who wants to do it, if it works. It does need to be the 6 cyl model, the 8's have a box. cool,it works. you can thank me at any stage.home all weekend Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted November 27, 2009 How does the length of the tie rods on the rack compare to the length of the tie rods coming off the pitman (I think that's what they're called) arms for the box? (edit) and while I am at it, how's the other geometry look (eg, arms roughly parallel with the lower control arms)? The ends are about 30mm shorter on each side now, will be ok I think at this stage, and I think I've got it sitting so the ends of the rack are close to what was already there, if you know what I mean. Most of the final setup will be done when I get the new rack in the race car. Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted November 27, 2009 (edited) Can you steal the inners from anouther model to get the ratio down? I find it really interesting that most jap stuff has a lock ratio much less than the euro's... i know misty have a high ratio rack of 2.8 in the mirages and the evo rs's have a 2.2 ratio rack in them. different models have anything in between those... i know the mirage boys hunt down the 2.4 and 2.6 racks for their cars... Edited November 27, 2009 by DRTDVL Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted November 27, 2009 Would make no difference, the rack is what it is. The tie rod end lengths are dictated by where the wheels are. Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted November 27, 2009 (edited) interesting i was under the impression that it was the size of the rack and pinion teeth/gearing that dictated the ratio... I might not be explaining what i'm thinking correctly... but the larger the gearing within the rack the more horizontal distance the rack will slide with less steering turn required... i'm only getting confused because of the quiafe upgrade kits you can get. http://www.quaife.co.uk/shop_category.cfm/...ategory_id/1281 <--- for a mk2 golf Edited November 27, 2009 by DRTDVL Quote Share this post Link to post Share on other sites
