jdk
E36 suspension advice?
Hey guys,
I got some cheap King Spings 2nd hand for the front of my 328i however once installed the car sits too low (illegal and not practical). Any recommendations? I saw a set of m3 springs on trademe...would they result in a drop from the 328 standard? How about coilovers?
Thanks
Edited by jdk
Coilovers if you want to spend the money on cert etc, or shocks + springs. Make sure you do your shocks too.
  3pedals said:
M 3 springs won't fit in a 328 and most coil overs are fashion items
What would you recommend then?
I'd recommend you talk to Keith at H&R Ph. 021378902 and get the right H&R or Vogtland springs to suit your car.
He is a sponsor here (SUSPENSION)....don't PM him.... ring him
H&R or simmilar good springs and My preference is Koni Sport adjustables
Clocked up over 500,000 km on various sets in the last 10 years
E36s are a pain to lower at the front aye. Low chassis rails make it very easy to become illegal before the car even appears lowered, I have been having endless problems. I'm after a set of low front springs if you want to sell them
that would probably explain why my car scrapes on most driveways (including my own :() even though it hasn't been lowered
Yeah I get that a bit, It also scrapes the inside guards and its standard height.
  Wom said:
that would probably explain why my car scrapes on most driveways (including my own :( ) even though it hasn't been lowered
that is probably more to do with the tyre size and wheel offset rather than anything suspension wise if they both still have factory suspension.
