bimmer1989 0 Report post Posted November 27, 2009 my car is miss firing but i dont know what it is?? i have changd the spark plgs on it Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 27, 2009 Has it overheated ? Is it using water ? Did you put diesel in it by mistake ? Have you just steam cleaned or water blasted it? Did you over rev it doing a ........ ? Have you been fiddling ? Failing that... it might be your dissy cap or leads More info might help Quote Share this post Link to post Share on other sites
bimmer1989 0 Report post Posted November 28, 2009 Has it overheated ? Is it using water ? Did you put diesel in it by mistake ? Have you just steam cleaned or water blasted it? Did you over rev it doing a ........ ? Have you been fiddling ? Failing that... it might be your dissy cap or leads More info might help must be te leads or omething then. because none of the above has happend that i know of. is any1 selling leads cheap?? Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted November 28, 2009 (edited) check rotor and dizzy cap see how worn they are. try removing a lead at a time and see if theres one that makes no difference when its unplugged. un plug at the head end of leads. Also have leads and cap cheap if needed. Pm me. Edited November 28, 2009 by 323e30 Quote Share this post Link to post Share on other sites
