e30ftw 433 Report post Posted December 1, 2009 Need to sell this stuff to clear some room. Prefer to sell it all together, But will separate possibly if I find I can get rid of it all. Far cheaper all together though ETA 2.7 m20 short block -10.2:1 CR ETA flat top pistons -ETA rods and ETA 2.7 Crank -Bought it low k's, 66,000. Must be at around 70,000kms now. 50ish as turbo. -Toothed front crank and Crank position sensor to run with Motronic 1.3 ECU's -New timing belt and tensioner and waterpump (~50k's on the tensioner and waterpump. Timing belt is less as i replaced it when changing to a steel headgasket). Still as new. - Can throw in a spare oil pump, And maybe a sump if I can find it. $500 M20 885 (325i) Rebuilt head Recently rebuilt, Less than 50k's on it. -New valve guides, valve stem seals, valve grind, rocker grind, crack tested, head skimmed, good condition cam swapped in. Head is mint, Surface is still smooth as it was sitting on a steel headgasket. $500 OR. $950 and you can get: -ETA 2.7 short block -885 rebuilt head -325i Intake manifold and Throttle body -Good alternator, Was bought as a serviced unit last year. -Dizzy cap, leads, coil -Front engine covers, pulleys etc. New power steering and waterpump/alternator belt. Quote Share this post Link to post Share on other sites
