Forrest
E30 Driveshaft Centering Sleeve Removal?
So I managed to destroy the little rubber bush with the metal ring on the front of my driveshaft.
(#1 in the part diagram)
http://www.realoem.com/bmw/showparts.do?mo...hg=26&fg=10
Ordered a new one from Gavin, has anyone replaced this before?
I can't seem to work out how to remove it before I get a chisel, BFH etc
Help?
Cheers, Nathan
Jam the tip that protrudes of it in a vice then tighten the vice and it'll bend it and twist your shaft til it comes out.
  e30ftw said:
Jam the tip that protrudes of it, bend it and twist your shaft til it comes out.
Hahahahahahahahaha (sorry I just had to).
Cheers John, I owe you a E-beer
All sorted and swapped old for new. The metal ring snapped in the vice, but a drill bit can cut a slot in the ring since it is really soft metal. Thanks John.
/End thread
Oh didn't realize it would probably be cast piece and crack lol. Oh well. Welcome anyways -_-
