tonylauno1 7 Report post Posted December 14, 2009 Occasionally yellow engine light stays on for a while after car starts so I thought oil level is at min, but the dipstick always show it's at max. Anyway oil was very dirty and it's been 12 months so I did an oil & filter change. Went for a drive to warm up and let it sit for 30mins then drain the oil. When topping up, I only used 5.5L when it should have been 6.5L, the dipstick shows it's at Max. I have a 328ci E46 (M52TUB28). Engine light still stays on occasionally after car starts for 10-15 seconds. It doesn't come on while driving, should I need to worry about this? Now the missing 1L of oil, I thought it maybe trap in the engine but it's still clean after 100km of the oil mixing with the old & new (if there is 1L of old dirty oil in engine). Is it normal that people only use 5.5L when doing an oil change? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 14, 2009 It should take 6.5 litres with a new oil filter. Either you are reading the dipstick wrong or the oil level sensor is faulty. 1 litre down will activate the oil level sensor... its meant to Quote Share this post Link to post Share on other sites
tonylauno1 7 Report post Posted December 15, 2009 Thanks Glenn, appreciate your input. Just checked the manual now, I am reading the dipstick correctly It is a little puzzling about only using 5.5L to get to Max on dipstick. I guess I'll wait till next oil change and see how much it needs. Quote Share this post Link to post Share on other sites
