antil33t 90 Report post Posted December 15, 2009 My new engine is filthy, much worse than my old B20. it's covered in yellow stains, I beleve this is oil stains? is there any way to clean this off bar painting it? any chemicals ect? Thanks. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted December 15, 2009 Its probably the protective wax it came with from the factory maybe. Try brake cleaner. Quote Share this post Link to post Share on other sites
turboprop 0 Report post Posted December 15, 2009 More commonly known as cosmoline I believe, its to protect the metal from corrosion. Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted December 15, 2009 ahh well, if it's to protect the metal I better leave it then eh? I'll just have to paint the intake manifold and cam cover eventually Quote Share this post Link to post Share on other sites
turboprop 0 Report post Posted December 15, 2009 ahh well, if it's to protect the metal I better leave it then eh? I'll just have to paint the intake manifold and cam cover eventually If you take it off it will be fine. Im not 100% sure but I thought it was for imported vehicles that came over on ships and was to prevent corrosion from the salt air / water. If you take it off, your valve cover / manifold isnt going to corrode. Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted December 15, 2009 I used a wire brush. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 15, 2009 i beleive paint stripper works Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted December 15, 2009 simple green works mint Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted December 15, 2009 Found some thinners downstairs, it's working very well. Just a bit hard atm since the cars on ramps, but at least I know it works Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted December 15, 2009 This can also be clear laquer that car dealers have sprayed on to give "the look". A look that certainly doesn't "look" later on Quote Share this post Link to post Share on other sites
