flake 0 Report post Posted December 19, 2009 (edited) hello again quick question: do i need to replace the sump gasket with new when i re-fit my sump? i'm doing an m50 converison on my e30, and the e34 sump that is used had a crack in it which i have just gotten back from being repaired. when i removed the e36 sump, the gasket stayed attached/stuck to the block and is pretty well on there. that seal will be fine i just wonder how the gasket to sump seal will be. is there a gasket sealant i can use or do i cut my loses and buy a new one. and where do i get one on a sunday morning ? cause depending on the whether, hopefullly i can get it in tomorrow cheers edit: typos everywhere Edited December 19, 2009 by flake Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted December 19, 2009 You NEED a new gasket. They are only supposed to be used once. Once they have been compressed and sealed, they are useless. So unless you wanna have a leaky oil pan I suggest you scrape the old gasket off and get a new gasket with some gasket sealant too for it too. Quote Share this post Link to post Share on other sites
Jono51 59 Report post Posted December 19, 2009 You NEED a new gasket. They are only supposed to be used once. Once they have been compressed and sealed, they are useless. So unless you wanna have a leaky oil pan I suggest you scrape the old gasket off and get a new gasket with some gasket sealant too for it too. +1 gasket goo won't last long do it once, get the gasket Quote Share this post Link to post Share on other sites
flake 0 Report post Posted December 19, 2009 thanks guys thats all i want to hear Quote Share this post Link to post Share on other sites
