JaseNZ
Outer ball joints and cab's
Ok so i have got these new solid out ball joints and cabs ready to go into my car. BMW here are quoting 250 to put put them in for me, If possible i would like to avoid having to do this and do it myself, Just a couple pf question's Once up on jacks if i remove the nut from the top off the ball joint will it drop down or it is it pressed in there as well. I have access to a workshop at work and they have a press (could i use this to press the balljoint out of the control arm ??).
Or do hire places have pickle forks they hire out ??.
Or best to leave it to BMW to swap them over. ??
Most workshops can do this repair at a much cheaper rate than that. I'd be quoting $150 + Gst retail to do that.
Yeah i thought that was a bit steep , May have to have a look around i think.
