savvi 0 Report post Posted December 20, 2009 hey all , heres some pics of my new daily runabout, 1991 320i abs aircon need it down in central otago, swapped the 15inch 5 spoke motoform wheels it had on it for my 16 inch hartges, was auto but converted to manual at some stage, has a jasma exaust that needs fitted properly at the rear just a bit to wobbly for my liking it must have a 4.1? diff in it i think which needs replaced for a medium case, cos 110kph in 5th = 4100rpm, not that economical on open road, got no reverse lights dont think it was wired up when conversion was done some advice here to remedy this would be a big help, for the next wof had the car two weeks, but yesterday i had to get toed back to cromwell thru the george as i was in qtown and parked up to do some xmas shopping, finished went to car after couple of hours and it wouldnt fire, turns over no prob, tryd some engine start spray in the intake and made a cough and splatter, seems theres no fuel getting to it i took off the fuel hose to the rail turned it over but there was nothing pumping thru and i cant here the fuel pump under left rear passenger side, i think its a fuel pump melfunction, i also put a test light on the fuel relay plugs next to air box they ok, any help or advice appreciated shane Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted December 20, 2009 (edited) Good to see you back Shane What happened to the Tec-1? Edited December 20, 2009 by KSMYRS Quote Share this post Link to post Share on other sites
savvi 0 Report post Posted December 20, 2009 Good to see you back Shane What happened to the Tec-1?hey chris hows it goin, ive still got the tech 1 just got no motor or box, going to be doing a 3.5 conversion or maybe bigger at some stage, hows the cossie goinghttp://www.bimmersport.co.nz/forums/index....showtopic=23464 Quote Share this post Link to post Share on other sites
savvi 0 Report post Posted December 21, 2009 anyone got any advice/help for me and my little problems i wrote about ? thanks Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted December 21, 2009 anyone got any advice/help for me and my little problems i wrote about ? thanks looks to be a bit of a self answering question but sounds like your fuel pump is dead. take it out and hotwire it straight to the battery (it wont kill it if you do connect it up, verify it does something then disconnect) and see what happens Quote Share this post Link to post Share on other sites
