Forrest 35 Report post Posted January 4, 2010 So I have just refitted the top black plastic piece of trim which covers the top of the lock barrel, steering column etc on a e30. In doing this, the orange plastic plug type thing that the wires run off on the LHS of the lock barrel on the steering column came off, so I refitted it with the lock piece slid back into it and now the car will not start and I am just welcomed to a buzzing noise with the turn of the key. What have I broken? Fuse/Relay/The whole car. Sorry in advance for the poor description, kinda need it sorted asap. Cheers, Nathan Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted January 4, 2010 take the trim back off. remove the plug and inspect all the wires and plugs. also check the tab where it interlocks into the back of the barrel. did it short out on the collum at all when it came off? Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted January 4, 2010 ^ Potentially could've shorted. What does that mean? It feels like a flat battery when you turn the key but all the dash lights light up etc apart from the service indicators if that means anything? All the soldered points and the tabs look fine. Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted January 4, 2010 Have you done the obvious and checked fuses? Fuse 10 in particular? Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted January 4, 2010 Yup checked all the fuses. Found I blew a resistor up in the flasher relay not that it should be related. And I am pretty sure its getting power to the key because all the lights still light up etc. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted January 4, 2010 This is the second day in a row bimmersport fail thread......where is my crown? Had the brake light sensor wires round the wrong way, so when I was off the brakes the lights were on, so battery is flat, so car won't start. Fail. The only reason I didn't notice is because I have a kill switch for the battery and didn't think it would go flat that fast. Now to see if I can start it with a new battery... Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted January 4, 2010 Mods can you delete this Chur Quote Share this post Link to post Share on other sites
