mattgoldsbro 0 Report post Posted January 12, 2010 1996 E36 328i Coupe (previous add below) ---------------------------------------------------------------------------------------------------- Hi all have just been to an auto sparkie as my drivers side window would not go up. We have managed to get window up for time being but seems i will need a new control unit which is located under glovebox. Has anyone on here got one for sale ?? Part # GMIV-LOW 12v BMW 61 35-8 369 483 109 110 (499508 -white stamp) HW 1.45W1.3 Is a black box/unit with yellow and blue sockets to one side / sorry no photo. Any help much appreciated, am located in Christchurch Thanks ---------------------------------------------------------------------------------------------------- 13/01/10 Hi all i recently put an add up on here for a replacement window control unit, as my drivers side window was stuck in the down posistion. Thanks to Ray from Hellbm i was able to get a replacement part and a good price ( Thanks Ray). So i changed the parts over and was working all good again untill yesterday when window was again stuck in lowered posistion. I can here the contol unit clicking when i hold button in both up and down posistion on the switch , but nothing from the window ??? When i originally had the auto sparkie look at this problem he told me he was pretty sure the control unit was the problem. Is there anything else it could be ?? The window motor was tested and seemed to be fine. Seems weird that worked for a little while with replacement part but now back to square one ?? Any help / ideas would be great thanks Matt Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 12, 2010 The window motors give alot of problems on coupes. Waste of time using second hand ones on the coupes. We fitted 2 into a members car yesterday. Quote Share this post Link to post Share on other sites
mattgoldsbro 0 Report post Posted January 12, 2010 The window motors give alot of problems on coupes. Waste of time using second hand ones on the coupes. We fitted 2 into a members car yesterday. Thanks Glenn , will look at replacing the motor !! The a annoying thing is just after posting this topic, tried window again and it worked. The motor does seem to be making alot of noise though, so will replace. Cheers Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted January 12, 2010 Plastic clicking noise? Recently had to replace my driver's door regulator after it chewed all the plastic teeth inside the regulator. It would wind down but not up Motor whirred away fine the whole time Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 12, 2010 Plastic clicking noise? Recently had to replace my driver's door regulator after it chewed all the plastic teeth inside the regulator. It would wind down but not up Motor whirred away fine the whole time E36 doesnt have the cable type regulator though Simon Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted January 12, 2010 (edited) Haha ok, well now he knows what to do when he downgrades to an E34 Fixed Edited January 12, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted January 12, 2010 sorry for the hi-jack, same topic but different window issue my window, if I hold down the Up button, or press it so it goes up automatically, it will more often than not go up a few centimetres then go back down a few centimetres from what I've read on the internet, it's a common problem to do with the magnet slipping out of place my question is ... is it an easy enough DYI fix? it looks to be simple enough on the internet, but never tried fixing an electric window before and should I replace the window motor or is it ok to just re-seat the magnet? (ie I don't want to have to do it again in 6 months time) Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 12, 2010 sorry for the hi-jack, same topic but different window issue my window, if I hold down the Up button, or press it so it goes up automatically, it will more often than not go up a few centimetres then go back down a few centimetres from what I've read on the internet, it's a common problem to do with the magnet slipping out of place my question is ... is it an easy enough DYI fix? it looks to be simple enough on the internet, but never tried fixing an electric window before and should I replace the window motor or is it ok to just re-seat the magnet? (ie I don't want to have to do it again in 6 months time) Fit a new motor... damn near impossible to fix on a coupe Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted January 12, 2010 ok cheers mate, thank you for the quick reply I think I'll drop it into Page Euro and get them to sort it, good blokes that work there Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 12, 2010 (edited) ok cheers mate, thank you for the quick reply I think I'll drop it into Page Euro and get them to sort it, good blokes that work there I can get a genuine (new) motor if you need one cheaper than the dealers Edited January 20, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
tehBMWn00p 2 Report post Posted January 20, 2010 (edited) I can get a genuine (new) motor if you need one cheaper than the dealersWhat's the price on one of these Glenn? I have the same problem as Wom. Edited January 20, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted January 20, 2010 Haha ok, well now he knows what to do when he downgrades to an E34 qft! Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted January 20, 2010 qft! Nasty Glenn editing my posts! I might have to delete the whole thread! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 20, 2010 (edited) What's the price on one of these Glenn? I have the same problem as Wom. They are on back order ATM... about 4 weeks $465.oo + Gst. They are genuine parallel imports Edited January 20, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 20, 2010 Nasty Glenn editing my posts! I might have to delete the whole thread! Took you a while to notice Si Quote Share this post Link to post Share on other sites
