Nobimmer
Name my diff
The only numbers I can find on it are 4332.
What does this mean?
Whats on the tag on the back plate under one of the bolts?
OK Ashkan, does it have 4 or 6 bolts on the side cover plates where the half shafts come out, 4 makes it small case, 6 id med case.
Then mark the drive shaft and output shafts and count the turns to get the ratio.
One turn on the half shaft should be between 3 and 4.5 turns of the drive shaft.
Awesome, cheers mate! It has 6 so med case, will count the turns tommorow and report back.
The number probably is there, under all the sh*t that has caked the diff!
clean your diff mate :huh:
there will be a tag like this
Edited by Brent HARTGE535i
