wellywally 0 Report post Posted January 20, 2010 (edited) I've looked at a 1997 M44 318ti compact that is mostly very tidy cosmetically. A few things are bothering me and I wondered what the general thoughts were. When looking at the engine it looked like there was a bit of oil coming from the rocker cover area... Am I looking at megabucks to replace this? Also on the inside the roof material is sagging a bit. Is it possible to somehow inject some glue in or is it a complete remove and replace job? Finally it is an m-sport but just has the m44 1.9l engine in it so is a bit of a sheep in wolf's clothing - is this and 3 series compacts generally detrimental to my masculinity??? Edited January 20, 2010 by wellywally Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 20, 2010 If the rocker cover gasket is leaking then it's a pretty cheap repair by replacing the gasket itself. Roof lining will need to be removed and repaired, easily doable. It probably just has the M body kit and badges fitted to it, you never know these days. Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted January 20, 2010 Finally it is an m-sport but just has the m44 1.9l engine in it so is a bit of a sheep in wolf's clothing - is this and 3 series compacts generally detrimental to my masculinity??? Haha if you're comfortable with your sexuality don't let it be a hindrance Seriously, they're good little cars - perhaps even underrated. The M44 is a good motor. You'll get all the Compact pundits launching in here shortly. Good luck with finding the right car Quote Share this post Link to post Share on other sites
Jono51 60 Report post Posted January 20, 2010 When looking at the engine it looked like there was a bit of oil coming from the rocker cover area... Am I looking at megabucks to replace this? Also on the inside the roof material is sagging a bit. Is it possible to somehow inject some glue in or is it a complete remove and replace job? yes seen a few sagging roof liners 2 options either replace with a second hand one or get it reupholstered rocker gaskets aren't a problem, just check that there are no leaks from the front motor covers too, that's when the price will start to get higher Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted January 20, 2010 Finally it is an m-sport but just has the m44 1.9l engine in it so is a bit of a sheep in wolf's clothing - is this and 3 series compacts generally detrimental to my masculinity???I got a compact and sure dont have a problem with my Masculinity.Mine gets up an goes well enough for me at the moment but plan on an upgrade some time this year. If you want to see what can be done to the Compact have a look at Glenn's build topic. Quote Share this post Link to post Share on other sites
wellywally 0 Report post Posted January 21, 2010 I got a compact and sure dont have a problem with my Masculinity. Mine gets up an goes well enough for me at the moment but plan on an upgrade some time this year. If you want to see what can be done to the Compact have a look at Glenn's build topic. Thanks all. Just lost a trade me auction (http://www.trademe.co.nz/Browse/Listing.aspx?id=265567075). the search continues Quote Share this post Link to post Share on other sites
