l0w320 0 Report post Posted January 27, 2010 want to buy one of the following: 320i manaul driveshaft for e30 or 325i manaul gearbox for e30... will buy whichever one is offered first... Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted January 27, 2010 There are two gearboxes you can use (240 and 260) - each has a different length driveshaft. Make sure you get matching driveshaft and box. Quote Share this post Link to post Share on other sites
l0w320 0 Report post Posted January 27, 2010 There are two gearboxes you can use (240 and 260) - each has a different length driveshaft. Make sure you get matching driveshaft and box. is the 240 and 260 both 325 gearboxes? Quote Share this post Link to post Share on other sites
Jono51 60 Report post Posted January 27, 2010 (edited) is the 240 and 260 both 325 gearboxes? no they are different boxes and driveshafts are different lengths if we are talking about the m20 240 was assigned to 320i 260 was assigned to 325i both will bolt up to the m20, however you need matching gearbox drive shaft note: 318 used a variant of the 240, this one differs to the m20 as the bell housing is slightly offset , if bolted to the m20 will create an issue lining up the shift linkage Edited January 27, 2010 by Jono51 Quote Share this post Link to post Share on other sites
l0w320 0 Report post Posted January 27, 2010 no they are different boxes and driveshafts are different lengths if we are talking about the m20 240 was assigned to 320i 260 was assigned to 325i both will bolt up to the m20, however you need matching gearbox drive shaft note: 318 used a variant of the 240, this one differs to the m20 as the bell housing is slightly offset , if bolted to the m20 will create an issue lining up the shift linkage alrighty well i have a 240 gearbox n just bought a 325 driveshaft thinking it would bolt up but obviously not so either looking for a 260 gearbox or a 320 driveshaft both have to be manual tho someone point me in the right direction! Quote Share this post Link to post Share on other sites
