e30ftw 432 Report post Posted January 30, 2010 I can't find much on the subject, but I am converting the battery to the boot on my 320i e30, have run a cable to the back etc mounted a terminal in the engine bay. I didn't get a battery tray and clamps when I bought the conversion stuff so I will probably get a battery box of trademe or something... But anyways what are people bolting the ground strap to? I see there is no place to bolt it down like you would find on a 325i anyways, so what can I do? I'm thinking getting a longer strap and sticking it to one of the bolts of RSM is a bad idea? Or would that do fine? Or is there somewhere more convenient? Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted January 30, 2010 Can you not bolt it onto the boot hinge mount? Only other place I can think of other than RSM. If you want that plate with the nut on it I can get mine out and send it to you. Obviously need to weld it. Quote Share this post Link to post Share on other sites
e30ftw 432 Report post Posted January 30, 2010 I can't see anywhere up where the boot hinge mount is? I see the end of the rear bumper protrudes into where the battery sits, Maybe I could use that as it will be touching chassis around it? If need be I will weld a bolt or whatever but trying to avoid that if I can.. Quote Share this post Link to post Share on other sites
