bretta 0 Report post Posted January 31, 2010 Hi All. My dad's 92 E36 320 sedan has had one of the aluminium holder drop off the bottom of the Front Passenger's window. What is the best glue to re-affix it? He went to Repco, and they told him Ados F2, but I'm not so sure this will be good enough. Any better suggestions will be gratefully received. After having done the driver's window on my e36, he now thinks I am guru on windows - so I don't want to dsappoint him! Cheers Brett Quote Share this post Link to post Share on other sites
HELLBM 1673 Report post Posted February 1, 2010 $30 at HELLBM Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted February 1, 2010 If you don't end up replacing it (which would be the easiest way), you want to use somethng slightly flexible that won't crack. Anything urethane based should work. Quote Share this post Link to post Share on other sites
