jochen 4 Report post Posted February 3, 2010 Well I'm adding support for E31 in NavCoder at the mo Which means E34 and E36 should also be supported, because they are the same generation... So I'd like some computer types - those who understand bits, nibbles and bytes - to try out NavCoder on their E34 or E36 ibus and let me know what they see! Ideally you should have the large OBC (MID) with all the bells and whistles, because that is the easiest to decode Who is willing to help document the databus? You need to be willing to focus on one message - eg door status - and document the opening and closing of doors, boot, bonnet, sunroof, fuel filler, etc. We can also look at some diagnostics data as well.... Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted February 3, 2010 sh*t I really need to change the bulbs in my OBC! Quote Share this post Link to post Share on other sites
JFry 1 Report post Posted February 4, 2010 I've got the 11 button OBC, would that be good enough? Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted February 4, 2010 More than willing to help Jochen, but don't know if I am technical enough. If you can give me specific instructions it shouldn't be a problem. 11 button OBC here too. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted February 4, 2010 Well I'm adding support for E31 in NavCoder at the mo Which means E34 and E36 should also be supported, because they are the same generation... So I'd like some computer types - those who understand bits, nibbles and bytes - to try out NavCoder on their E34 or E36 ibus and let me know what they see! Ideally you should have the large OBC (MID) with all the bells and whistles, because that is the easiest to decode Who is willing to help document the databus? You need to be willing to focus on one message - eg door status - and document the opening and closing of doors, boot, bonnet, sunroof, fuel filler, etc. We can also look at some diagnostics data as well.... i have the "full" obc and would be interested but not up to your level... Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted February 4, 2010 Well here's how: NavCoder shows data like this: 31.01.2010 15:09:11.812: 09 04 02 81 00 8E 31.01.2010 15:09:11.812: ZKE2 --> EKM : Door status, Data="00" Here we have Door Status, 1 x Byte A Byte is 8 bits Doors are generally bit mapped So we can record 8 x on/off states EXAMPLE: ---- ---x : Drivers Door, 1=open, 0=closed Not that hard... very simple really... Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted February 4, 2010 Pop me an email bud with what you require ... Am up at rays quite a bit .. and im sure he wont mind Quote Share this post Link to post Share on other sites
