lukenewguy 0 Report post Posted February 6, 2010 has any one out the put a face lift sump guard under a south african pfl m20. need advice before purchase. Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted February 6, 2010 The chassis are the same, so I would say yes it will fit. Quote Share this post Link to post Share on other sites
bmpower 3 Report post Posted February 6, 2010 I have one in wgtn if you need one. Quote Share this post Link to post Share on other sites
ducatiss 1 Report post Posted February 7, 2010 Yes I have - and yes they will fit up no problem. Quote Share this post Link to post Share on other sites
lukenewguy 0 Report post Posted February 7, 2010 Yes I have - and yes they will fit up no problem. sweet thanks for that do i just need to drill holes to mount it? Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted February 7, 2010 (edited) the cars that come stock with these sump guards actually have threaded rod welded to the chassis rail for the side mounting points. To fit these to other models you may need to drill the chassis and fit threaded rivets in so you can bolt it on. Cant remember the real name for the threaded rivets at the moment tho. south african models may have the mounting points already there ? (for the metal sump guards) Edited February 7, 2010 by 323e30 Quote Share this post Link to post Share on other sites
lukenewguy 0 Report post Posted February 7, 2010 the cars that come stock with these sump guards actually have threaded rod welded to the chassis rail for the side mounting points. To fit these to other models you may need to drill the chassis and fit threaded rivets in so you can bolt it on. Cant remember the real name for the threaded rivets at the moment tho. south african models may have the mounting points already there ? (for the metal sump guards) sweet thanks for the advise from all of you Quote Share this post Link to post Share on other sites
