charles28 142 Report post Posted February 6, 2010 But now the cars not running well over 4000rpm under heavy acceleration, it hesitates and feels like its losing power. Its idling fine and running fine at low engine speeds (better then before). What have I done? lol Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted February 6, 2010 This will sound stupid, i put some fuel in it and now its fine.. It was down between emtpy and 1/4 a tank.. so should have been fine.. could this be fuel pump related? maybe fuel filter? Cheers Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted February 7, 2010 You might have had some crap stuck in the injectors after running the tank low Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted February 10, 2010 it could be a blocked fuel filter, I doubt it would be a pump problem. Does your car have 1 or 2 pumps? It sounds to me like either the mesh on the pump pickup is blocked up or you were sucking up just enough air to not allow enough pressure to build to deliver fuel at high rpm. Quote Share this post Link to post Share on other sites
