hybrid 1045 Report post Posted February 2, 2005 (edited) Am looking later this year / early next year on getting an ESS suprcharger unit (the 8psi model) http://www.esstuning.com/default.asp?c=sho...subcat2=114&id= It will run around 8PSI and be good for 325HP (DIN) aliluya I know you brother use to run an ESS one on his 330, How did he get on with the octane ratings ? In NZ we have 98 (RON) (which is what I put in anyways), they recommend a abolute minimum of 95 (RON) octane ( to prevent detonation) How did your brother get on with the aussie fuels ... also now that hes running 400kw hows he getting on ? I take it you turbo guys have lowered your compression to compensate ? I will be keeping the internals stock. cheers Edited February 2, 2005 by hybrid Quote Share this post Link to post Share on other sites
