rnbluva 0 Report post Posted March 6, 2010 Hi guys i have a little problem, my brake fluid for the clutch leaks out. Cant engage it anymore, the fluid just leaks out completely. The clutch pedal just sits flat on the floor if i push it in I'm not the most mechanically minded person so bear with me if what im saying dosent make any sense lol I think it might be the slave cylinder? or something along those lines. Are parts cheap? How much would it cost approximately to get it fixed? Just trying to get an estimate so that i can try get some money together The brakes are fine so i guess i have to be thankful that the two are separated. Any helpo would be really appreciated! Thanks! Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted March 6, 2010 yes you will most likly need a new slave cylinder about $60-100 from a brake and clutch place etc . about a 30min job to swap over Quote Share this post Link to post Share on other sites
rnbluva 0 Report post Posted March 6, 2010 yes you will most likly need a new slave cylinder about $60-100 from a brake and clutch place etc . about a 30min job to swap over thanks for the reply, do you know of any specific place i could get one? Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted March 6, 2010 BNT have slave cylinders they are cheap as chips. Quote Share this post Link to post Share on other sites
