djguranga
Replaced e30 front struts with e36s incl springs and now..
Having bent my front left from from unsuccessful rock climbing efforts :P, ended up throwing both out and replacing with better e36 struts and springs (had to replace left control arm too doh!)
car is def riding better yet only problem i now have is tyre-onto-wheel arch scraping on the left side especially on dips and highs when turning left..car has been aligned by mag n turbo since shocks have been replaced.
is the best plan to get the guards rolled? or is there anything i can look into adjusting?
cheers :D
Did you replace the whole strut/insert/spring/hub? How?
If it's pushed your wheels further out, you would probably want to sort out why it has done so before you go rolling the gaurds.
Having bent my front left from from unsuccessful rock climbing efforts :P , ended up throwing both out and replacing with better e36 struts and springs (had to replace left control arm too doh!)
cheers :D
Ummm longer springs, lower profile tyres?
Edited by ducatiss
did you go to 5 stud?
i would be guessing if you did you need to sort out the caster. to do this you will need offset conrol arm bushes, and possibly 96+ m3 conrol arms
Must be M3 evo arms to work properly.
The car still has the original e30 hubs on both sides (4 stud). The work was carried out by Ray @ HellBM. Just wondering if I should go to a suspension specialist or something and get them to check the entire setup?
Really? Wow ok sorry mate didnt know, i shall give Ray a call and see exactly what was changed over. Will get sum photos on the weekend. Cheers for your help chirs :)
