WRKNL8
FM Expander - Installation
Hi,
I am looking at installaing an FM expander on my 99 e46 business stereo unit and need to know how to get to the back of the head unit to plug the expander. I have taken off the cover under the steering column and managed to find a 12V source but cant find my way to the antenna jack.
Does anyone have any instructions please? hopefully I wont have to take too many bits off. Any help will be appreciated.
Thanks
Hi,
Thanks
Easy.
Pull off the trim panel left and right of the radio. They are just pressed, in, so pull them off CAREFULLY AND EVENLY. I use plastic bicycle tyre levels to do the job, works well.
Then remove 2 x screws (left and right of radio) and the radio slides out
Unplug connectors as required.
The radio has switched 12V and also permanent 12V on the radio connector
Antenna connector is DIN type, you may need a DIN-to-Japanese antenna connector adapter.
Hi,
Thanks
UPDATE:
Managed to find the instructions on google - worked a treat! http://www.fitaudio.com/?View=entry&EntryID=97
Easy.
Thanks for the helpful hints mate.
