deeveus 81 Report post Posted March 24, 2010 When I set my seat (electric memory) drivers side it's fine. However next time I get in the car it's returned to a higher upright position. No other direction/modification has been changed, only the back foward back position is. Any ideas anyone? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 24, 2010 (edited) What happens if you set your seat, press memory 1, get out of the car, lock it and reopen it ? How many keys have you got ? and what happens when you use the other key ? Edited March 24, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
deeveus 81 Report post Posted March 24, 2010 I've got my settings set on memory 1, so when I get back in I ether adjust the upright or just press 1 till it sorts it. I have 3 keys, 2 normal, 1 skeleton, doesn't seem to make any difference, although I will double check with the other one. Locking & re-opening is what sets it off. Cheers. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 24, 2010 (edited) If you reinitialise the keys so you know which one is No1 and which is No2. Then set memory for key 1 & then key 2 it should work properly. Or pop into the dealer to get them to do it...there could be a hickup in there Edited March 24, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
