danutt 4 Report post Posted March 26, 2010 not from the engine bay so it cant be vanos when i drive over bumps i can hear its coming from the back i think?? any ideas or someone had this issue on an e36 before?? cheers damian Quote Share this post Link to post Share on other sites
JFry 1 Report post Posted March 26, 2010 My rear brake pads are the wrong size, so they rattle when I go over bumps. I first thought rear shock mounts, until I figured out it was the pads. Shock mounts are more of a thump apparently... Would recommend getting under the car and looking for wear or loose bits. Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted March 26, 2010 Yep, i have the same rattle mainly when i drive over light bumps...will check the shock mounts when i have some time! Quote Share this post Link to post Share on other sites
danutt 4 Report post Posted March 26, 2010 FOUND IT!!!! yes!!! just so you know it was the brake pads...theres a 3 prong fitting that clips into the plunger on the brakes and it did not have any clip on it so if you wernt braking it would rattle against the disc hope this helps you both out aswell:) cheers damian Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 26, 2010 FOUND IT!!!! yes!!! just so you know it was the brake pads...theres a 3 prong fitting that clips into the plunger on the brakes and it did not have any clip on it so if you wernt braking it would rattle against the disc hope this helps you both out aswell:) cheers damian Thats quite common with aftermarket pads... thats why we wont supply & fit them Quote Share this post Link to post Share on other sites
danutt 4 Report post Posted March 26, 2010 Thats quite common with aftermarket pads... thats why we wont supply & fit them well it was the last owner that put them in..i know better hahacheers Quote Share this post Link to post Share on other sites
