rogan 17 Report post Posted March 26, 2010 Re-installed my factory system and everything works except the FM reception which is abysmal. I had no problems with FM reception on the aftermarket unit I just pulled out. No wires were chopped or cut while installing or uninstalling the aftermarket stereo so I'm a bit baffled. I've fiddled with the aerial on the back of the headunit and it feels secure, likewise than small metal connector in the middle. The aerial amp (if that's what it is) is in the boot above the cd changer. This seems secure and wiring is firmly clipped in. Any suggestions on where to look next. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted March 26, 2010 check the skinny white wire has 12volts positive on it when the stereo is on at the back of the stereo and teh aerial amp. that supplys power to the aerial amp unit . Quote Share this post Link to post Share on other sites
rogan 17 Report post Posted April 2, 2010 Sorted. Main aerial connection on rear of headunit wasn't mating properly. Quote Share this post Link to post Share on other sites
