Eddie 66 Report post Posted March 27, 2010 Are there any M44/M42 nuts on here It looks like the camshafts are adjustable- slotted holes behind the retaining bolts Is the socket doweled? If I undo the four bolts holding on the socket can I change the cam timing? Does anyone have a photo of the cam shaft encoder off a M42? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 27, 2010 The sprockets are not doweled. Yes you can adjust the cam timing, either using the proper tools or dialing it in to suit a specific setting Quote Share this post Link to post Share on other sites
