htra024
E46 wheels advise
They should, 3 series offsets are normally similar to the holdens. Tyres are probably too big and will mess with your speedo heaps.
I think you really need to find out the offset! Holden pcd are 5x120 which i know fits e36 and e46's the rubber should be ok as mine is on 235/40/18's...mind you slightly stretched, so i wouldn't think would put the speedo out!
Sorry, tyres should be fine, are similar to oem on 18s. Wasn't really thinking when I posted that.
