pommy
engine bolts
I have noticed that the engine bolts on one side are loose! I have managed to tighten two of them, but the last one on the mount seems to turn i think the last owner may of threaded it any suggestions?
thanks.
oh its on the m42 engine mount if that helps?
Take the lose one out, it may be the bolt that's stripped, you may just need to change it.
no I have bought new bolts because one was nt there. It starts to screw in then it just turns!
