westie88
cant diagnose engine fault
:banghead: iI over-reved my engine causing it to imeadiatly to lose power.theres no smoke and starts okay,idles a little rough but backfires through the intake when reved.
at 1st i thought it was a head gasket or valve related but there seems to be no mechanical fault and theres no water surging in the radiator.
im thinking it could be timing related or an intake leak. the timing can not be adjusted manualy as it is motronic .
is there a common fault relating to censors or the computer ? any other suggestions?arrrrrgh!
did you over rev on down change or did you just rev to redline. If you over revved on down change then there is every likelyhood that the timing belt (m20 motor) or chain (e36 and newer) has jumped a tooth.
its an auto so it poped when i hit the kickdown,ive been told that if the cambelt had jumped it would be hard to start or would not start at all.i will check it out anyway.I just want to be sure what the problem is before i go ripping out the radiator or head to get to it.
check the compression, That'll determine whether or not you have a bent valve or something gay like that, don't go rushing into pulling the head off just yet...... It's not smoking, using water, or knocking?? breathing any heavier through the crankcase breather than normal???
wont be rocker arms in my opnion, I dont see how it could have hit anywhere near 8k just on the auto kickdown
also could be something as tedious such as leads or a crook plug or something stupid like that, cracked dizzy cap, broken the tip off the distributor rotor maybe?(i dont know bmw engine distributors that well)
worth a try
Put a couple of squirts of oil into the cylinders before taking a reading. If the compressions comes up alot from a 'dry' test, you have ring damage. Possable even piston damage.
