b mike w 0 Report post Posted April 27, 2010 hey guys just wondering if anyone can help me. when accelerating under load (not in neutral) in between the rev range 1500-2000 there is a rattle in the engine bay. it goes away after 2000rpm and doesn't occur when i give it some guts. just wondering if this is anything to be worried about or if it could be a loose spring or bit of metal. thanks guys Quote Share this post Link to post Share on other sites
tire 10 Report post Posted April 27, 2010 Is it a m10 e30? Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted April 27, 2010 Its an '86 320i.. M20 Quote Share this post Link to post Share on other sites
b mike w 0 Report post Posted April 27, 2010 Its an '86 320i.. M20 yeah thats right. 1986 m20b20 Quote Share this post Link to post Share on other sites
c.robertson00 11 Report post Posted April 27, 2010 Release bearing or lay shaft bearings in the gearbox. Dont worry about it. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 27, 2010 hey guys just wondering if anyone can help me. when accelerating under load (not in neutral) in between the rev range 1500-2000 there is a rattle in the engine bay. it goes away after 2000rpm and doesn't occur when i give it some guts. just wondering if this is anything to be worried about or if it could be a loose spring or bit of metal. thanks guys From your description, it could be many things. If you can't isolate the fault yourself I would suggest to be on the safe side to get it checked by a professional conversant with BMW's. It may be something minor, then again it may not. What fuel do you use ? are you sure it's not detonation (pinking) ? Quote Share this post Link to post Share on other sites
b mike w 0 Report post Posted April 28, 2010 From your description, it could be many things. If you can't isolate the fault yourself I would suggest to be on the safe side to get it checked by a professional conversant with BMW's. It may be something minor, then again it may not. What fuel do you use ? are you sure it's not detonation (pinking) ? I use 95. Its not detonation. I know that sound. Its a tinny sound thats y I thought it might just be a loose spring or something. Quote Share this post Link to post Share on other sites
