hihaterz 0 Report post Posted April 28, 2010 Hi Guys, I have an overheating problem, on the OBC it says' CHECK COOLANT LEVEL' I checked the coolant level and everything is ok but it still seems to overheat, when I open the bonnet I hear a "hissssssssing sound" as if there is a leak in a pipe or hose?? What could it be? Thanks Ryan Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 28, 2010 If you can here the noise, you should be able to locate where its coming from. Don't drive it and get professional advise if you are not able to do it yourself. Quote Share this post Link to post Share on other sites
hihaterz 0 Report post Posted April 28, 2010 If you can here the noise, you should be able to locate where its coming from. Don't drive it and get professional advise if you are not able to do it yourself. Ill come make an appointment by you guys today. Thanks, Quote Share this post Link to post Share on other sites
