bmwNewbe 0 Report post Posted May 3, 2010 hi all. i have an e46 2000 pre facelift and it only has rear fog lights so was wondering if it is possible to put in a light unit with the front/rear fog switch and wire up the front fogs from there? the fog wiring loom isnt a problem its just a case if im able to use another control unit or not and if any programing needs done or not as alot of e46 systems need programed. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 3, 2010 Chassis # ? Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted May 3, 2010 hi all. i have an e46 2000 pre facelift and it only has rear fog lights so was wondering if it is possible to put in a light unit with the front/rear fog switch and wire up the front fogs from there? the fog wiring loom isnt a problem its just a case if im able to use another control unit or not and if any programing needs done or not as alot of e46 systems need programed. Answers to your questions: Q1 = yes Q2 = yes, programming required Quote Share this post Link to post Share on other sites
bmwNewbe 0 Report post Posted May 4, 2010 Answers to your questions: Q1 = yes Q2 = yes, programming required dont suppose you know off hand what pins you go from on the lcm multiplug? also is it only bmw can program the lcm or can the pa-soft bmw software do it as a friend has it and would mean it would be possible then to do all myself. thanks for the responce. Quote Share this post Link to post Share on other sites
