bmwNewbe 0 Report post Posted May 6, 2010 hi was wondering if anyone has a pinout of the bmw microfone or has managed to wire up a 3.5mm jack to the end of it for an aftermarket fone kit so im able to install origonal mic. basicly i have a mic and finnish grill also the 3 pin plug and i wish to install/solder a 3.5mm jack on to the end but its only 2 wire so am thinking the 3rd wire is for bi-directional pickup or mono/ster sound. if its either then i should be alble to use 2 wires for just mono or for drivers side pick up but would need the pin out to find out. Quote Share this post Link to post Share on other sites
Dogballs 123 Report post Posted May 6, 2010 try this Quote Share this post Link to post Share on other sites
bmwNewbe 0 Report post Posted May 6, 2010 try this correct me if you think differnt but as a standered mic only has a positive and sheilded ground i should get away with only wiring up those 2 pins and if that dont work then put the 3rd pin to the body of the car. thank for the pin outs will be a great help. Quote Share this post Link to post Share on other sites
