danutt
power steering woes e36!please help me out
ok so i knew the pump was stuffed..previous owner didnt notice screeching noise :angry:
got a second hand pump..defintily in better shape than the one i took out and doesnt make any noise on rotation unlike the broken one
do i put the new pump on and took out the old fluid by draining it and turning the wheel lock to lock several times
added fluid and fired her up
turned the wheels etc and added fluid
problem is this:
i had an intermitant vibration through the steering wheel at stand still with the old pump
with the new pump, i have a constant vibration through steering wheel until around 1200rpm and it goes away steering is better than before:angry:
could the vibration be from air still in the system?
wont be engine mounts because there was no vibration ony now since the pump change
vanos is not rattling and idle is fine but engine seems slightly rougher??
any help would be appreciated, thanx in advance
Edited by danutt
if the vibration was from air in the system it would only vibrate when you turn the wheel.. if that is the case then i suspect thats what it would be. if not, have you checked that the motor or exhaust isnot touching the steering rack or collum or anything?
will jack it up today and check that out cheers mate
but if its not that what could be the issue?
ummm nothing really. if your getting a bad vibe through the steering wheel when engine is running and your not turning or moving or anything then it will be something touching the steering thats vibrating.. not really much else it can be.
double checked the install of the new pump and did everything correctly
took the serpentine belt off and ran the car for 5 secs when it was cold and there was no vibration
so it hasto be something to do with the power steering since i changed it
had another look at the pipes and the large pipe that goes to the reservoir has 2 bends in it and could be starving the pump causing vibration?
cheers
if the bends look like kinks then yes, take off the pipes and blow through them, make sure fluid is getting through and they are not blocked... i guess a pump with no fluid around (may) cause your problem but usually they are just noisey if there is air in them... try bleeding it again 1st and see if that helps, failing that just go through and check that nothing is blocked and that lines are round the right way, fluids goin through etc...
EDIT: just thought of it... if the valves in the power steer rack are dodgy then that may cause the problem.. not 100%sure on that though..
Edited by e30li
ok so i put a new straight pipe on it bled it and its still there soooo
took pump off and going to get another second hand one hopefully this time its in better nick haha
the rack doesnt leak out of the boots and the boots arnt filled with fluid so im guessing the valves are still all good
the original pump gave an intermitant vibration hence i decided to change it before it damaged the rack
now the second hand one vibrates more so hopefully the second second hand one will be a charm hahaha
got new pump in and fresh fluid worked a treat no vibration problem solved :)
well after putting another second hand one in there was very little vibration at first
decided to take it for a drive and the vibration slowly came back along with heavier steering
think i need to get a brand new pump now and thats $$$
does anyone know how much they are or have a contact i could maybe use to get one cheaper??:)
Pumps dont normally give problems...it may be a restricted or collapsed (internaly) power steering hose. Get it checked by a specialist
before i get the rack checked which i might add has no leaks not even from the boots
are there rebuild kits for the pump? i see a few online but how about around auckland? haha
the kit replaces the bearings and seals in the pump and are (by the looks of it) under 50 bux for the kit
maybe rebuild and rule out the pump as the culprit
cheers
^ Don't bother throwing money at it until you get it diagnosed, spend the money once, not twice. I don't know how many times Glenn says that on here.
Good luck.
Good luck.
will take it to a friend on monday then il know for sure...pump or rack...
thanks for the help will keep posting until the problem is solved
cheers
cheers
ok so if anybody else comes accross this problem its the engine mounts well at least one of them
apparently the heat causes them to fail
im sending the coupe in either wednesday or thursday and will post the results:)
hopefully it sorts it out and i can move on to the next fix....the door handle hahha
cheers
cheers
found the problem!!!
alternator bearings are bad and worn causing the vibration:)
pump was either on its way out or fluid was crap but never the less its better now and all i need is a good alternator:)
cheers for the input :)
