Polymer 0 Report post Posted June 1, 2010 Hey guys, A friend of mine has a 2003 E46 Compact, It started running really badly recently and it recently got a scan test done on it. They said it came up with P1341 P1343 P1345 fault codes which all had to do with misfire but didn't pin point it. They said it would need further testing. I googled those codes and it came up with the codes they said and something about fuel cut. Can anyone shed any light on this to point me in the right direction? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 1, 2010 Where abouts are you. Those codes mean nothing to me. I can scan it properly for you. Most common faults are ignition coils, camshaft sensors & MAF sensor.. or you can call me (09)2722546 Quote Share this post Link to post Share on other sites
Polymer 0 Report post Posted June 1, 2010 I'm in wellington, im guessing your in auckland Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 1, 2010 I'm in wellington, im guessing your in auckland Yes I'm in Auckland otherwise I could check it for you. I'd suggest getting the dealer check it for you. We have found that some of the generic scanners give false error codes. We also dont use those codes. Live data must also be checked on these vehicles when diagnosing faults. Quote Share this post Link to post Share on other sites
Polymer 0 Report post Posted June 2, 2010 Cheers, discovered a melted air hose on top of the manifold, replaced it, all good. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 2, 2010 Cheers, discovered a melted air hose on top of the manifold, replaced it, all good. Thats common too... the main breather hose... it will give many error codes relating to O2 out of scale readings Quote Share this post Link to post Share on other sites
