dubman
e30 rear springs
Rear springs, mine dont sit properly and bounce too much. e30 1989 316i coupe.
edit: want ones that sit at similar height. cheers
Edited by dubman
have a set of bilstein springs for 4 cylinder E30.200 take it away.PM me if you want
high mitch, after rears only, as i have 51mm front struts.
I use these spring with 51mm struts.but they design the spring rate for lighter M40 and M20 weight too heavy.
I have my old OEM springs if needed. From 4 cylinder e30. PM me if thats what your after.
Edited by bmw3
