BM WORLD 1291 Report post Posted June 4, 2010 have this kit in a e39 98 528iT at work, is it any good , says you need a nav cd etc . can it be made to work in NZ , whats involved?? Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 4, 2010 have this kit in a e39 98 528iT at work, is it any good , says you need a nav cd etc . can it be made to work in NZ , whats involved?? Yes! That car / nav system is ex-Japan To use in in NZ, replace the Japanese nav drive with a standard Euro Mk3 or Mk4 nav unit and it will work. When replacing the drive, you will need to change the connectors on the wiring loom for the nav, but that is straight forward Note: for the radio to work in NZ, you will need to replace the radio tuner with the equivalent Euro tuner. Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted June 4, 2010 Yes! That car / nav system is ex-Japan To use in in NZ, replace the Japanese nav drive with a standard Euro Mk3 or Mk4 nav unit and it will work. When replacing the drive, you will need to change the connectors on the wiring loom for the nav, but that is straight forward Note: for the radio to work in NZ, you will need to replace the radio tuner with the equivalent Euro tuner. hi thanks , probably not worth it for us as we will just be on selling it , what sort of cost do these units go for . thanks brent Quote Share this post Link to post Share on other sites
