NoBoDy 0 Report post Posted June 8, 2010 I have a E36 318IS, currently on 17" M3 Wheels with 205/40 front tyres and 215/45 Rear(i think) i put in some B&G springs and the back is fine but the front is very low, chassie rails sit about 75mm off the ground and its a pain to pull in and out of anywhere that has even a slight ramp lol, What brand of springs have other people used to keep the front legal or almost legal. Cheers Chris Quote Share this post Link to post Share on other sites
zenetti 0 Report post Posted June 8, 2010 (edited) I have a E36 318IS, currently on 17" M3 Wheels with 205/40 front tyres and 215/45 Rear(i think) i put in some B&G springs and the back is fine but the front is very low, chassie rails sit about 75mm off the ground and its a pain to pull in and out of anywhere that has even a slight ramp lol, What brand of springs have other people used to keep the front legal or almost legal. Cheers Chris There is nothing wrong with the springs. the tyres you have on at the front are far too small for your car. You need the same size as the rear. Edited June 8, 2010 by zenetti Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 8, 2010 I'm certed at 75mm and don't have any problems. You might find you are lower. Height is the problem more than the spring type. Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted June 8, 2010 (edited) There is nothing wrong with the springs. the tyres you have on at the front are far too small for your car. You need the same size as the rear. My thoughts too. You should be running wider tires than that anyway. 225-235, Then again i guess you don't need it on a 1.8. Edited June 8, 2010 by Mike-E36 Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted June 8, 2010 75mm makes it seem like a 4wd compared to mine... im working on a fix at the moment but i feel your pain. ohh and bigger front tyres will help it a billion times over. Quote Share this post Link to post Share on other sites
NoBoDy 0 Report post Posted June 9, 2010 sweet cheers they are 17x7.5 ill work out the tyre heights and see what i can come up with Quote Share this post Link to post Share on other sites
