bigrob
Problem with Merc ML
A mates year 2000 ML270 is leaking 'heaps' of water from under the heater controls on dash,took dash apart & couldnt find source & nothing obvious in engine bay too.Any1 come across anything similar or have an idea to whats going on?
If it's rain water, its possibly the pollen filter drain blocked. If it's coolant, most likely the heater matrix. I suggest you get it professionaly checked before the leak causes other damage
