joshnz 2 Report post Posted June 11, 2010 Morning all, the last couple of weeks I have noticed, only on the first couple of cold starts in the morning, my M52B28 loves to emit a rattle for literally a second or two then it goes away. Its hard to pin-point in the engine bay because its over with so quick - anyone heard anything similar before? Its quite a chattery rattle if that makes any sense. Car has been serviced well and had only done 102ks. Quote Share this post Link to post Share on other sites
mattgoldsbro 0 Report post Posted June 11, 2010 Morning all, the last couple of weeks I have noticed, only on the first couple of cold starts in the morning, my M52B28 loves to emit a rattle for literally a second or two then it goes away. Its hard to pin-point in the engine bay because its over with so quick - anyone heard anything similar before? Its quite a chattery rattle if that makes any sense. Car has been serviced well and had only done 102ks. Maybe starter motor? Mine seems to a make a bit of noise on cold starts sometimes ,just for a split second. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 11, 2010 Drive belt idler & tensioner bearings will do this Quote Share this post Link to post Share on other sites
joshnz 2 Report post Posted June 11, 2010 Dare I ask is that fixable - and at what sort of ballpark figure? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 11, 2010 (edited) Dare I ask is that fixable - and at what sort of ballpark figure? Get someone to start it for you cold and use a screwdriver as a stethescope to locate the noise. Remove the drive belts and check the bearings. Its normally the alternator ones that cause the problem. There are two types of tensioners and 2 different set ups. Check the bearings and give me a chassis # if you want prices Edited June 11, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
joshnz 2 Report post Posted June 11, 2010 Cheers Glenn Quote Share this post Link to post Share on other sites
