sammcj2000 1 Report post Posted June 12, 2010 (edited) Need a working E36 Lock Actuator for my 96' 328 coupe. The current one doesn't seem to work properly with the remote central locking. FYI on this common issue: http://good-times.webshots.com/album/557789582nyYUxv?start=0 Edited June 12, 2010 by sammcj Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 12, 2010 Are you sure it's the central lock motor ? Who diagnosed the fault for you ? Quote Share this post Link to post Share on other sites
sammcj2000 1 Report post Posted June 12, 2010 Are you sure it's the central lock motor ? Who diagnosed the fault for you ? I ripped out the actuator and applied voltage to the rear pins, I can make it lock by moving the lever off the 'door is locked' microswitch but I can't make it unlock again. The motor works in both directions with voltage directly applied. With a multimeter we could see the +12 and -12v charge when the doors are locked / unlocked. Sound right? Quote Share this post Link to post Share on other sites
Jono51 60 Report post Posted June 13, 2010 we have what you need cheers Jon and Keren 04 3801089 Quote Share this post Link to post Share on other sites
