Ben 0 Report post Posted June 13, 2010 After much procrastination Ive decided to sell my turbo kit. It will not include the turbo, wastegate, FMIC or plumbing but includes the following... # Bottom mount turbo manifold (T3/T4 flange 38mm turbosmart WG flange) # Oil feed line # Oil return line (Drains to the sump plug) # Dump pipe (can include V band flange if you want it) Everything is a straight bolt on besides the dump pipe which needs to be welded to the front section of your exhaust. I also have a set of 240cc replacement injectors which should support 8psi on either M50b20 or b25 with the aid of a fuel controller and 540i MAF. $550ono for everything including injectors Will post pics soon Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted June 15, 2010 (edited) interested mate, could you text me when you update with pics (have limited internet currently), am doing m50 E30 swap soon and want to turbo .... unsure if manifold will fit in a E30 though... will be in touch with some questions re measurements of manifold hopefully! edit: 027 465 2223 Edited June 15, 2010 by HT. Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted June 15, 2010 (edited) Quick its Andrews cell number, everybody spam him. Edited June 15, 2010 by M-Spec Quote Share this post Link to post Share on other sites
