kwhelan 242 Report post Posted June 13, 2010 Im trying to add a reverse camera trigger to pin 17 of the audio video module and also hook up the camera feed to the inputs, is this 61-13-0-005-197 the correct part for the pins and are they availably locally,can they be ordered from bmw directly or is ther something local available cheaply from computer parts or the like Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted June 13, 2010 (edited) Can't remember & can't find offhand the part number for the terminals but they can be got from dealer. They come individually as a terminal with a black cable (about 6" long) already attached. Not aware of being available elsewhere but if you find out - I would like to know Edit - From BMW - there are actually a couple of options with these terminals/leads - difference being the wire size Edited June 13, 2010 by hotwire Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 13, 2010 Im trying to add a reverse camera trigger to pin 17 of the audio video module and also hook up the camera feed to the inputs, is this 61-13-0-005-197 the correct part for the pins and are they availably locally,can they be ordered from bmw directly or is ther something local available cheaply from computer parts or the like Go to a wreckers, cut a plug off a loom, and you'll loads of pins (+ wire if you cut the cable a ways back...) Quote Share this post Link to post Share on other sites
kwhelan 242 Report post Posted June 13, 2010 Go to a wreckers, cut a plug off a loom, and you'll loads of pins (+ wire if you cut the cable a ways back...) why did I not think of that cheers Actually in the wagon there is a much larger version of a similar looking audio video plug sitting bare under the floor just behind the radio, any ideas what this is for Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted June 14, 2010 why did I not think of that cheers Actually in the wagon there is a much larger version of a similar looking audio video plug sitting bare under the floor just behind the radio, any ideas what this is for Telephone. So easy to make telephone work in your car, get a ULF or a TCU and volia! Integrated bluetooth. Make sure you confirm wiring of the phone connector before plugging in to the ULF or the TCU because there were many different wiring options for the many different telephone options. Quote Share this post Link to post Share on other sites
