antil33t
Diffs
Wasn't sure where to put this.
But, this fella on trademe is stripping a few BMW's locally.
I'm after a diff with a taller ratio, sick of the fuel economy.
He has a 4:10 out out of an 86 318i which I guess is a PFL. I also guess it's a small casing.
He has an E34 520i too (he never said anything about the diff) (would that fit??)
No, it won't...
Would the older 4:10 be fine, or should I look out for something else?
Gear calculator reckons I should be around 2,500rpm @ 100kph, instead of the 2900-3000~ that I do now.
Cheers.
Edited by antil33t
What tyre size are you running and is your gearbox 1:1 in 5th or .8 : 1 ?
BTW: What ratio diff are you running ATM ??
Edited by *Glenn*
Top Gear is 0.73 (it's auto)
Tyres, 195/65/14 (stock weaves)
I realise auto isn't exactly the best, but if I went manual the car would rev even higher in 5th.
Yes your present RPM @ 100kph is 2.900RPM
A 3.64:1 would give you 2,300 rpm in top gear
I have a medium case 3.64:1 open diff here in good working order...new side seals, new oil and I've had the back off to check it $250 if your interested.
You would need a 3.15:1 or a 2.97:1 for manual if the gearbox was 1:1
The 3.64:1 would still be ok for a manual gearbox with a .8:1 output ratio
Edited by *Glenn*
my 325 auto has a 3.6 and it is about right for what u want... and all model e30 diffs are interchangeable
Ahh, that's what I want to hear Oli.
Cheers Glenn, Will keep that in mind ;)
