mitchE30 0 Report post Posted June 17, 2010 my 535i going die,looking for one good running E34 M30 engine pit into it.but they have different system.what things I need to do. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted June 17, 2010 you could just the e34 535i engine with the complete e28 535i wiring loom and ecu etc . swap all teh manifolds and other bits other. also you will most likly have to make up some new engine mounts as the later engines dont have the casting for teh old mounts etc e34 535i has less power and torque because it has less compression than the e28 engine . i have a good e28 535i 10;1cr engine sitting in my shed , had a newly built up head on it etc before i removed it and fitted a m5 engine. Quote Share this post Link to post Share on other sites
