Gunner 0 Report post Posted June 19, 2010 (edited) Okay so today I dedicated myself to fix any possible blocks in the drains for some basic maintenance. Did my sunroof, doors and i think my scuttle/cowell drain. I have read lots of different forum posts all over the internet and noticed that some cars have 3 drains some have 2 while others have 1... from my inspection I could only find 1 noticeable scuttle drain right behind the cylinder heads. Since my car is a 1994 coupe, are there 2 or 3 scuttle drains or just the 1 that i managed to get to..? Really wanna give the others a good clearing if there are more cause the 1 i have cleared so far was disgusting and full of moist crap.. Edited June 19, 2010 by Brenton Quote Share this post Link to post Share on other sites
beeeamer 0 Report post Posted June 19, 2010 did you find these instructions? i havent followed them yet myself but may be different to some you've found http://www.bimmerforums.co.uk/forum/f3/how...-drains-t32501/ Quote Share this post Link to post Share on other sites
Gunner 0 Report post Posted June 19, 2010 Yea followed those. Found 1 with the rubber drain but when i was feeling around for another i just found a hole that when into the area where the heater core motor was so i am now assuming that thats were the other one was supposed to be? based on the images from that page with the 2 drains i think im just missing the rubber pipe there. Quote Share this post Link to post Share on other sites
soarer260@hotmail.com 0 Report post Posted June 19, 2010 Hmmm how are you planning to clear the blockages if they are present? I recently used a blow vac to clear out all the crap under my vent cover, so many leaves and other bits of debris Quote Share this post Link to post Share on other sites
Gunner 0 Report post Posted June 19, 2010 I used a rubber stick to break up the leaves and dried gunk, then used my vacuum. To clear the rubber drain I did what they suggested in the post above with the link. Used a bit of wire and pushed it thru a little first, then pushed it against the side of the rubber to pull it down. Managed to remove a lot of gunk by doing that but took a while to move my hands in the tight spots Quote Share this post Link to post Share on other sites
Gunner 0 Report post Posted June 19, 2010 Oh and can someone please tell me how to locate the air con drain area cause I noticed today while testing my air on in the garage I left it on for about 5-10 mins running and looked under the car but no puddle.. went away for a while and came back and noticed that underneath the carpet was damper. I think the drain isn't connected or its clogged. Where about should I be looking to find it ifs clogged? Thanks for the help so far everyone:D Quote Share this post Link to post Share on other sites
