Syxx 0 Report post Posted June 19, 2010 Hey again, Window came off the runners the other day, managed to wedge it up a bit but still let in abit of rain, buggered around with it tonight and figured how to get it back on the runners, SORTED. However now when the window winds up instead of going neatly with the seal it heads wing mirror down so that theres a gap at the front and the only way to have it go up right is to bugger around holding the back end of it. So my question is why is it doing this and how do I fix it? Cheers. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 19, 2010 If you fixed it with new plastic guide clips I would say that the regulator arms are bent or the window is not fitting in the front window guide channel properly Quote Share this post Link to post Share on other sites
Syxx 0 Report post Posted June 20, 2010 If you fixed it with new plastic guide clips I would say that the regulator arms are bent or the window is not fitting in the front window guide channel properly I used the same plastic clips, Will have a look and see what I can suss out. Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted June 20, 2010 can supply new clips and secondhand regulators check the bracket hasn't popped off the glass, can supply glass too cheers Jon 04 3801089 Quote Share this post Link to post Share on other sites
